Help with intake manifold
Old Dec 10, 2006 | 04:40 PM
bcdalton's Avatar
bcdalton
Default Help with intake manifold
Does anybody know how difficult it is to install an intake manifold and how long the job will take? I'm thinking of purchasing a Magnum V8 Stage 2 OEM Intake Manifold from Hughes Engines. Any response would greatly be appreciated. Thanks!
Old Dec 10, 2006 | 11:36 PM
dsertdog56's Avatar
dsertdog56
Default RE: Help with intake manifold
It's not difficult, but time consuming if you've never done it before. I'm sure if you run a forum search you'll find more info. You'd be better off asking specific ? s, or pick up a haynes or chilton manual.
Old Dec 11, 2006 | 01:15 AM
timwag2001's Avatar
timwag2001
its real easy. takes a while. if you havent gotten that in-depth with taking your truck apart then i would plan on it being down for a day. keep your parts that you take off well organized. after you take off a part, slide the bolts back into the holes that they came from so that you dont confuse where they go.
Old Dec 11, 2006 | 02:11 AM
Tani1500's Avatar
Tani1500
yea its easy, look in the DIY forum for the Plenum gasket replacement. that will basicly tell you exactly how to do it.
Old Dec 11, 2006 | 03:37 AM
bcdalton's Avatar
bcdalton
dsertdog56, timwag2001, Tani1500- Thank you all for your responses and advice. I'll do more research on this and buy a Haynes manual. Once again thank you.
Old Dec 11, 2006 | 04:34 PM
dirty dog's Avatar
dirty dog
when you get it on tell us about it cause thats what im going to order after christmas
Old Dec 11, 2006 | 04:58 PM
bcdalton's Avatar
bcdalton
Dirty Dog- I'll definitely do that. Hopefully, I'll have everything done right before the New Year.
Old Dec 11, 2006 | 05:36 PM
steve05ram360's Avatar
steve05ram360
ORIGINAL: bcdalton
get the FSM from the merry christmas thread @ the top of the forum... it's in the dodge info thread... better than the haynes
Old Dec 11, 2006 | 06:20 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Plan on spending a weekend on it if it's your first time. I'm betting you'll get in there and want to clean up parts, inspects hoses, etc. That's what I would do if I were you. It's a good time for some preventative maintenance.
Old Dec 11, 2006 | 06:36 PM
bcdalton's Avatar
bcdalton
steve05ram360- Thanks! I'll do that.
VWandDodge- Thanks for your input, also. I'll definitively want to do some preventative maintenance while doing the job. I appreciate everybody's willingness to help and knowledgeable advice. This forum is great.
