cam pos. sensor. !!! prob solved, burning oil now
Old Dec 15, 2006 | 03:38 PM
gcguru's Avatar
gcguru
Default RE: need help camshaft pos. sensor. !!! prob solved, burning oil now
if it didnt smoke before the sensor went bad, then you probably have a bad spark plug wire or similar from playing around under the hood. Not likely that the rings suddenly went bad while you were fixing the crank sensor
