Crankshaft Position Sensor Modification... WHere is it??? Please help...
Old Dec 15, 2006 | 02:56 AM
bikemx423's Avatar
bikemx423
Default Crankshaft Position Sensor Modification... WHere is it??? Please help...
I feel sooo dumb for posting this... But I am trying to find my Crankshaft Position Sensor... Where is it located? By the oil filter, or like on the front by the belt??
Thanks so much guys
Old Dec 15, 2006 | 03:16 AM
nim81's Avatar
nim81
Default RE: Crankshaft Position Sensor Modification... WHere is it??? Please help...
on the back of the engine under the tranny dipstick on the passenger side. top side of motor
Old Dec 15, 2006 | 03:20 AM
bikemx423's Avatar
bikemx423
ok thanks bro!
Old Dec 15, 2006 | 03:28 AM
bikemx423's Avatar
bikemx423
Alright I am 100% complete dumb ****~! I am sorry but i cant find it... I have a manual so i dont have a trans dip stick... is it on the intake manifold area, or by the starter?? Or like the thing 2" above the oil filter...
I am having a bad night... haha.. a million things are happening.
Old Dec 15, 2006 | 04:01 AM
Scottr1110's Avatar
Scottr1110
it is right behind the right head by the firewall if u run ur hand down the back u should feel it
Old Dec 15, 2006 | 10:22 AM
turkeyhunter1962's Avatar
turkeyhunter1962
As Scottr1110 stated it is right behind the passenger side head. Feel for where the transmission and engine meet and then find the rubber grommet on the transmission.The CPS is mounted in such a way that it fits inside the grommet and senses the openings in the flex plate as it spins between the engine and torque converter. At the top of the CPS you will fins wiring that runs upward and if it is like mine the wiring leads behind the distributor.
Finally found a picture that I could include. This should help.
[IMG]local://upfiles/35230/F7629F943887438BBD7C15D0C93D35E1.jpg[/IMG]
Old Dec 15, 2006 | 12:12 PM
Silver_Dodge's Avatar
Silver_Dodge
How are you all getting back there to mod it anyway, pullling the engine? [&:] Not much room back there.
Old Dec 15, 2006 | 12:21 PM
nim81's Avatar
nim81
i have a body lift so i can just reach between the frame and the body, might be harder for someone with stock ride.
Old Dec 15, 2006 | 04:51 PM
turkeyhunter1962
To do the mod you disconnect the electrical connection, remove the two bolts, and pull the CPS out of the rubber grommet. The remove the rubber grommet. On your workbench is where you can elongate the CPS mounting holes, then you just re-install it without the rubber grommet in place. Before you tighten the bolts, slide the CPS as far as your elongated holes wil lallow you toward the oil filter then tighten. If you encounter pinging, loosen the bolts and slide the CPS a little away from the oil filter and re-tighten the bolts.
I can reach mine from on top after removing my cold air intake. Some people prefer to do this from underneath. I guess whatever your preference is.
Old Dec 15, 2006 | 05:47 PM
Ramdamit98's Avatar
Ramdamit98
Here's a pic from turkeyhunter1962's gallery with the engine out. You can see the notch in the transmission bell housing where the crankshaft position sensor mounts into. I've taken mine out from underneath and a buddies from above. I had better luck from underneath just because I could see what I was doing a little better.
[IMG]local://upfiles/32197/31BF88F998154175B58FF1129AD04D30.jpg[/IMG]
