Engine Squeek?
Old Dec 20, 2006 | 12:10 PM
TexasEd's Avatar
TexasEd
Default Engine Squeek?
Was driving my 2001 Ram 5.2 yesterday and noticed a loud engine squeek or squeel sound as I sat at idle. I raised the hood with the engine running and tried to figure out if it was a pulley,the power steering pump, or the compressor. I couldn't figure out exactly where the sound was coming from but I'm sure I can find it.Does a squeeking component as I mentioned requireareplacement? Has anyone else had this problem? Thanks in advance for comments/suggestions.
Old Dec 20, 2006 | 03:42 PM
nim81's Avatar
nim81
Default RE: Engine Squeek?
take your belt off and see if any of the pullys are loose or give them a spin to see if the grind, most likely its a idler pully or tensinor pully.
Old Dec 20, 2006 | 03:52 PM
RamGoat's Avatar
RamGoat
Last time I heard a squeak under the hood the water pump broke. Fortunately it wasn't my truck.[8D]
Old Dec 20, 2006 | 03:56 PM
Win11Cup's Avatar
Win11Cup
I had a bad squeek about a month ago and it ended up being the pulley on the alternator. Tried some belt ease and it would stop it for a few seconds, then it was very easy to pinpoint when it started again. I also ended up changing the serpentine belt after I had covered it in belt ease.
Old Dec 20, 2006 | 10:07 PM
TexasEd's Avatar
TexasEd
If it does prove to be a pulley I assume it willneed to be replaced? Should I first try lubricating the belt? Thanks in advance.
Old Dec 21, 2006 | 01:38 AM
timwag2001's Avatar
timwag2001
ive got a squeek to. its my leak detection pump.
