outside brake lights
Old Dec 27, 2006 | 04:07 AM
toomuchpeso's Avatar
toomuchpeso
Default outside brake lights
My brake lights don't work when I step on the pedal. The taillights, turn signals and flashers work but the brake lights don't. The 3rd light won't work either. The fuse for the stop lamp is good. What else should I check?
Old Dec 27, 2006 | 04:11 AM
whiteram00's Avatar
whiteram00
Default RE: outside brake lights
dunno if the ram is the same but there is a switch behind the brake pedal,it may be bad or may even came alose,check that
Old Dec 28, 2006 | 01:28 AM
Aubrey's Avatar
Aubrey
I take it you replaced the fuse inside the truck. There's another one under the hood in the fuse box behind the battery.
