Window Regulator
Old Dec 28, 2006 | 12:48 PM
steelpony06's Avatar
steelpony06
Default Window Regulator
I have a 2000 Dodge Ram Quad Cab with electric windows. The driver's side window sometimes works and sometimes does not. When the window is halfway I have to grab the window to assist the window to the full up position. The motor sounds weak when the window is moving up but sounds normal when the window moves to the down position. Can anyone help me with my symptons and if you think it is the window regulator, where can I find one other than the dealer?
Old Dec 28, 2006 | 05:54 PM
mntnceguy's Avatar
mntnceguy
Default RE: Window Regulator
Does sound like a weak regulator motor. But I have seen on some other vehicles that the window can get hung up on the rubber window track if it has a rip or worn spot in it. Jeep Liberty is notorious for that, never seen it on a Ram though. After you have tested all the wiring and switches, and are for sure its the regulator, you can get everything you'll ever need from www.moparmaster.com. They are like haveing access to the dealers parts list, at discounted prices. Good Luck
