98 1500 Idle Problem
Old Dec 28, 2006 | 09:53 PM
Tayborg5's Avatar
Tayborg5
Default 98 1500 Idle Problem
I have a 1998 1500 Ram 5.2L and it seems to drive fine but the idle just started to get rough on me. I had a check engine light come on shortly after the rough idles, heres wat i got, Cylinder 2 & 7 misfire and Random Multiple Cylinder misfire detected. ?????????????????? I thought maybee fouled spark plugs and its been driven 700+ miles in the past days. So i changed the spark plugs and cleared the codes. And im still getting the same thing, engine light came back on, and idles the same.
Help me here?? Im gonna check the wires in the morning. Any help would be appreitiated.
Old Dec 29, 2006 | 02:58 AM
timwag2001's Avatar
timwag2001
Default RE: 98 1500 Idle Problem
check your spark plug wires for damage. lift your hood when its dark out and look for a blue arcing from your wires. theres a tsb out for the wire routing of your truck that i guess can cause misfires. http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
hope this helps.
