Water pump problem *fixed*
Old Dec 29, 2006 | 03:15 PM
BradBeyer's Avatar
BradBeyer
Default Water pump problem *fixed*
Ok I was driving home last night and I split the hose between the water pump and intake...bought a new one. Then I found out my water pump was bad also so I put a new one on.
Here is my question:
[ol][*]Now I have no heatbut the vehicle is not overheating....running really hot though...could there be blockage somewhere?[*]My alternator is not working either does that mean I fired it or does it need to dry out?[/ol]
Help please and thanks for your time
Brad (all info about my truck is in the signature)
Old Dec 29, 2006 | 03:23 PM
Chopper1's Avatar
Chopper1
Default RE: Water pump problem
Sounds like you need to let it run till warm, open radiator cap(while running) and add more fluid. Make sure the fluid is moving. Patience let it run a while.Did you take time putting the t-stat pipe on so the t-stat didn't move. Dumb question, but have to ask, are you sure it is not upside down. At some point it will get hot enough to open, but usually late.
Old Dec 29, 2006 | 03:28 PM
BradBeyer's Avatar
BradBeyer
I drove it to work..about 15 miles and it never got over 240 but the heater was blowing cold air...did not take the thermostat out and it was working before I changed the water pump.
Brad
Old Dec 29, 2006 | 03:37 PM
Chopper1's Avatar
Chopper1
Check the belt routing......and tension...
Old Dec 29, 2006 | 03:51 PM
BradBeyer's Avatar
BradBeyer
Belt tension is perfect but is it possible to have the belt on wrong? Could it turn the water pump the wrong direction?
Brad
Old Dec 29, 2006 | 04:59 PM
BradBeyer's Avatar
BradBeyer
Default RE: Water pump problem *fixed*
Chopper1 thank you that is exactly what it was...I had the belt on wrong....Do you thinkI could have damaged anything?
Brad
Old Dec 29, 2006 | 05:18 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
If you never got over 240º you'll be fine.
Old Dec 30, 2006 | 04:00 AM
steve05ram360's Avatar
steve05ram360
also, make sure you get all the air bubbles out of the system... now that the belt is on there right, you may still have air trapped in the system.
