lost 1st gear 46re transmission
Old Jan 3, 2007 | 06:43 PM
kinaiahi's Avatar
kinaiahi
Default lost 1st gear 46re transmission
Aloha, I lost first gear in my 46re tranny. All of the other gears seam to work fine. Even if I downshift with the shifter it seems like it only goes to 2nd gear. Any ideas? Is this indicative of a governor pressure solenoid? Or any other solenoids for that matter? Any help is greatly appreciated, this is my only vehicle and I need it to go to work!!! Happy New Year
Old Jan 3, 2007 | 08:51 PM
topsites's Avatar
topsites
Default RE: lost 1st gear 46re transmission
Does reverse work?
Old Jan 3, 2007 | 09:41 PM
kinaiahi's Avatar
kinaiahi
reverse and every other gear works fine. Just went to the dealer to pick up the governor pressure solenoid, and transducer. Hopefully these are the problems, 'cause with these and the filter and oil, its up to $300.
Old Jan 4, 2007 | 03:29 AM
johnalm's Avatar
johnalm
put those in and you should be fine.
Old Jan 4, 2007 | 06:59 PM
kinaiahi's Avatar
kinaiahi
Default fixed it
Put the two sensors in, changed the filter, added oil, took her for a test drive, and she's driving great. Only thing, does anyone know who makes a tool to adjust the band adjustment screw. The head is square with rounded edges?
Old Jan 4, 2007 | 07:27 PM
timwag2001's Avatar
timwag2001
Default RE: fixed it
i think i used a 12 point socket. i think it was an 8mm
i'll get back to you in a minute and tell you for sure
Old Jan 4, 2007 | 07:41 PM
timwag2001's Avatar
timwag2001
scratch the 8 mm. i think it was a 5/16 12pt socket.
