2500/3500 coils on 1500
Old Jan 6, 2007 | 08:26 PM
01ramjam's Avatar
01ramjam
Default 2500/3500 coils on 1500
I have a 2001 1500 4wd and i have a 3 inch bds lift. Im wanting to get it up there though and i heard that you could put coils from a 1 tonon the 1500 and get 3 inches left. Has anybody out there ever done this or know if it will work.
Old Jan 6, 2007 | 08:52 PM
ddog737374's Avatar
ddog737374
Default RE: 2500/3500 coils on 1500
yea it will work but its going to ride alot stiffer ifI where you Id buy a coil spacer or a longer spring made for a 1500
Old Jan 6, 2007 | 10:12 PM
johnalm's Avatar
johnalm
i did this to my 94. close to 3 inches. does ride harder, but i did it for my plow. the stock spring were to soft even being new.
Old Jan 7, 2007 | 01:37 AM
chrishag's Avatar
chrishag
ORIGINAL: johnalm
I did the same thing and a AAL in the rear rides alot stiffer but now it handles the plows like a champ.
Old Jan 7, 2007 | 03:22 AM
01ramjam's Avatar
01ramjam
Doanyone know of a place that sales just the lift springs for a 1500
Old Jan 7, 2007 | 03:38 PM
dsertdog56's Avatar
dsertdog56
Any good 4x4 shop...Top gun customs on ebay or 4wheelcustoms online. Skyjacker's part number for a 3 inch spring is D30. I believe BDS makes a 3 inch spring, but really, you might consider dumping the spacer and getting a 6 inch spring.
Now the fine print...adding another 3 inches to a 3 inch lift is gonna uncenter your axle both ways, moving it to the left and back. To do it RIGHT, you'll need longer control arms and you really should go to a DT or similar style adjustable track bar. I'd seriously go to a Cepek style long arm assembly because your ride will be VERY choppy. You'll also get some bump steer, so you should invest in a droppittman arm as well.
When you start lifting a Ram over 5 inches, you're really getting into the big leagues(no pun intended). It takes more then a couple of springs to make the truck function properly and most importantly SAFE.
Old Jan 8, 2007 | 01:42 AM
01ramjam's Avatar
01ramjam
I dont think ive ever had it in 4 lo always hi theres not many places with a big mudd pit or bog where i live. Do you know what all i would need to get it up higher without having to buy a $1600 kit and it still be right.
Old Jan 8, 2007 | 01:55 AM
dirty_d's Avatar
dirty_d
i got the 3500 diesel springs on my 01 1500 it does ride stiffer but i think it handles better on road, doesn't dive into cornersit gave me an extra 1.5 inches on top of the coil spacer and lift kit
Old Jan 8, 2007 | 02:45 AM
dsertdog56's Avatar
dsertdog56
A bit of savy searching could probably get it done for less than a grand. You could probably use short arms off a 5 inch lift, but getting a good track bar and pittman arm will be your biggest expense.
Old Jan 9, 2007 | 01:43 AM
01ramjam's Avatar
01ramjam
Thanks for all the help. Hopefully i can get something done know that i know it will work.
