1/2 to 3/4 hub switch
Old Jan 7, 2007 | 04:05 AM
wildcardwes's Avatar
wildcardwes
Default 1/2 to 3/4 hub switch
I recently trashed the front axle on my 1998 1500 4x4 and have located a complete 3/4 ton suspension. I would like to do the swap, but I really don't want to have to switch out my 5 lug wheels. Does anyone know if the hubs will interchange? Thanks!
Old Jan 7, 2007 | 02:27 PM
baltimore's Avatar
baltimore
Default RE: 1/2 to 3/4 hub switch
i am woundering if a 1ton rear would work on my 1500 i really do not care about the lugs but i know the gear ratio needs to be the same. i see you know the front will work. do you know if the rear on a 2001 will work also, or can you steer me in the right direction?
Old Jan 7, 2007 | 08:45 PM
01OffRoadster's Avatar
01OffRoadster
No, the hubs have differant bolt patterns. It would be an axle swap as well to change the rears, and that won't work either.
Old Jan 7, 2007 | 11:41 PM
Tani1500's Avatar
Tani1500
ok since im trying to go to one tons, ill give you guys some of the info i know. any dana 60 front from a sec gen dodge is a direct bolt in. all ou have to do is get a diffent u joint for the driveshaft. dana 60 and 70 rear are also the same way. most dana 60's wont fit a 15inch rim but the caliber could be grinded and it should fit, depending on year of axle. the rear your going to need adifferent driveshaft for. the hubs from a 1/2 and 1 ton arnt interchangable. although there is a guy onpirate4x4 that makes 5 lug hubs for the 60 but there alot of cash.
when i do my swap im just gunna swap in a dana 60 front and leave the 9.25 in the rear since its a pretty beefy axle anyway. then convert the 9.25 to 8 lug using the shafts out of a dodge 2500 8 lug van ( which is a 8 lug 9.25)
