Help Breather Element
Old Jan 7, 2007 | 05:12 PM
2 Marks's Avatar
2 Marks
Default Help Breather Element
Folks,
I took the breather element out to clean it but can't get it back in. What's the trick? Thanks.
Old Jan 7, 2007 | 06:28 PM
2 Marks's Avatar
2 Marks
Default RE: Help Breather Element
Figured it out... the trick is to take the outer rubber grumet off from the plastic stem/valve. The rubber grumet goes back in easily; then insert the plastic stem/valve. There is a lip on the valve so you will need pliers to pull the peices apart. I hope this saves you all some time.
