Is there a difference....
Old Jan 9, 2007 | 02:09 AM
974x4's Avatar
974x4
Default Is there a difference....
is there a difference between a 96 intake and a 97 intake off of a 360???
Old Jan 9, 2007 | 03:24 AM
RM_Indy's Avatar
RM_Indy
Default RE: Is there a difference....
No difference between 96-02 that Im aware of. Im using an egr version of the M1 on my 96 which is intended for a 94-95. Wanted the egr one cause of the threaded hole inside between the runner openings to allow me to bolt in a large turtle instead of cementing it in.
Old Jan 9, 2007 | 06:11 AM
974x4's Avatar
974x4
k thanks. was jus wonderin cause i found a '96 intake, am goin to get the runners cut, and get it ported. thxs
Old Jan 11, 2007 | 02:05 AM
Aubrey's Avatar
Aubrey
Indy, I've heard different things. Can you run the turtle in an M1 on a '95 360? I was told it will make them run like garbage. Also, how much is it and do you just order it along with the M1? - thanks
