Bilsteins
Old Jan 11, 2007 | 12:17 PM
IndyRamMan's Avatar
IndyRamMan
Default RE: Bilsteins
if they all look like that your gonna have a fun time tryin to get teh front to fit methinks. though i dont know what the front setup looks like on 4x4
Old Jan 11, 2007 | 12:34 PM
bamory's Avatar
bamory
Post style at the top, grommet hole @ the bottom, loosen the top post, unbolt the bottom, remove the 3 pillar bolts pull the shock/tower straight out the top, rears are pretty much like 99% of all other shocks........
Hint.....I have sprayed PB Blast on for the last week, and with air tools should be pretty simple.
Old Jan 12, 2007 | 02:27 AM
dhvaughan's Avatar
dhvaughan
i changed my original shocks awhile back. the front tops came off with no problems, and i used an impact wrench on all the others, so no problems there either. on the fronts i found it easier to jack up the body a little and extend the shock, so that when i took off the tower the shock wasn't pushing up on it. when you put the front bottoms back on tighten to 100+ pounds or they will rattle.
