Oil Pan
Old Jan 11, 2007 | 01:24 AM
stevejh's Avatar
stevejh
Default Oil Pan
Id like to replace the stock oil pan witha new one and i found this one on ebay and if it will work, i plan on buying it.
http://cgi.ebay.com/ebaymotors/360-M...69385730QQrdZ1
Ive got the 5.9 (360) and the oil pan is for a rear sump. I just thought id double check and make sure its a good envestment before I bought it.
Old Jan 11, 2007 | 01:32 AM
timwag2001's Avatar
timwag2001
Default RE: Oil Pan
i like it... i'm gonna out bid you!
just kidding.
Old Jan 11, 2007 | 01:35 AM
johnalm's Avatar
johnalm
Default RE: Oil Pan
that pan is for 71-80 a-engine and will not fit your truck. buy one from a dealer that way you know it will fit. if you pull the pan down most of the time the gasket will stay in place and can be reused if it dont tear when the pan is removed. i have done this several times.
