Installing a BOA remote starter & lock
Old Jan 15, 2007 | 01:04 AM
Glideman88's Avatar
Glideman88
Default Installing a BOA remote starter & lock
I started to install an Boa remote system in my truck today. So far everthing is fairly straight forward with the starter portion of the installation and after doing a search of these forums, I see that I'll have to use a relay to Neg. trigger the parking lights.
BUT for some reason I'm stumped as to how to wire up the door locks.
I printed out the wire color code sheet from the BOA website a couple weeks ago but I'm not sure which wires to use. The sheet lists both a (power lock & unlock) anddoor motor (lock & unlock) and the installation manual is sort of vague about which "type" of door lock system our trucks have?
Does anyone here have an experience with the BOA installs? This isreally embarrassing to ask as I'm actually one of the Electronics Techs where I work.
Old Jan 15, 2007 | 03:51 AM
habeba86's Avatar
habeba86
Default RE: Installing a BOA remote starter & lock
We have the 5-wire lock system.....what model is it....?
Even tho you said you had it..
12volts red and pink/black + ignition harness
Starter yellow + ignition harness
Second Starter
Ignition dk. blue + ignition harness
Second Ignition
Third Ignition
Accessory black/orange + ignition harness
Second Accessory black/white + ignition harness
Keysense
Power Lock orange/purple 5wi driver door harness
Power Unlock pink/purple 5wi driver door harness
Lock Motor orange/black driver door harness
Unlock Motor pink/black driver door harness
Parking Lights+ black/yellow headlight switch
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger yellow - headlight switch or DKP
Dome Supervision use door trigger
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm lt. green/orange - driver door harness
Factory Alarm Disarm same wire
Disarm No Unlock
Tachometer black/gray ignition coil
Wait to start orange/black - center of firewall, black plug
Brake Wire white/tan + brake pedal switch
Parking Brake
Horn Trigger black/red - steering column
Interface Modules
Smart Starter Kill Relays
MAKE : DODGE | MODEL : RAM PICKUP | YEAR : 2001
Old Jan 15, 2007 | 04:07 AM
ddog737374's Avatar
ddog737374
i have the same thing as you but i never could get my door looks to work they keep blowing the fuse so i just never hooked them up
Old Jan 15, 2007 | 04:12 AM
habeba86's Avatar
habeba86
You have to use a relay or if you can do it with your particular remote start use a relay module...
Old Jan 15, 2007 | 05:11 AM
Glideman88's Avatar
Glideman88
ORIGINAL: habeba86
It is the BOA model 265B
So do I connect the control box wires to the "power lock & unlock" wires? Or to the "lock & unlock motor" wires? And is the fused purple controller wire hook to any 12v constant source?
I know this make me sound dense but I'm actually losing sleep tonight trying to figure out what probably is a really simple thing.....
P.S. THANK YOU in advance for the assistance!
Old Jan 15, 2007 | 01:24 PM
01sportram's Avatar
01sportram
This isnt the remote system you are using but they have good wiring diagrams. http://www.bulldogsecurity.com/
Old Jan 15, 2007 | 01:47 PM
White Ram's Avatar
White Ram
I also have the BOA 265B, but I haven't installed it yet. Prolly gonna take a day off next week to install it, so I'm watching this post with great interest.
Sorry I can't help right now.
Habeba86 - What do you mean use a relay for the power door locks - can you be more specific?
Old Jan 15, 2007 | 02:04 PM
JarheadX's Avatar
JarheadX
I never heard of BOA. My mom bought me mine at the stereo shop. 150 installed, i didn't complain. Sorry i can't really help.
Old Jan 15, 2007 | 04:49 PM
dr_destruction's Avatar
dr_destruction
I do a couple hundred R/S's a year at my shop. Hope this helps. If you need help with the wiring on the relays just let me know. I can walk you through that. If you have factory keyless, the "central timer module" is above the gas pedal. You can find lock and unlock there, you will just use a positive 12v trigger for lock and the you will need to cut the pink/green and run the switch side of the wire to pin # 87a, the motor side to pin# 30, constant 12volt to pin # 87 & #85, and a negative unlock trigger from your 265 R/S to pin # 86. I beleive the Boa only has negative outputs for the doorlocks, if thats the case, you will also need a relay for the positve 12volt lock. You need to convert from negative to positive. Pin # 30 & #86 get constant 12volt, negative trigger on # 85 from the Boa and positive out to the orange/green door lock wire. If you dont have the CTM above the gas peadl, you need to "5-wire" both the lock and unlock.
Keyless models use positive trigger for lock, and 5-wire for unlock. Can also find wires at the central timer module to the right side of the steering column, lock is orange/green, unlock is pink/green.
Old Jan 16, 2007 | 11:07 PM
dishdude2k's Avatar
dishdude2k
i have installed several of these power lock systems.. usually i have made the locks myself.. but there are a few that i have used factory.. usually the wire coming out for power lock / unlock are what you will need to use.. but yes.. you HAVE to use a relay.. when you lock.. it sends your voltage one way.. when you unlock it sends it the other way.. check out ebay.. they sell the remote lock relay modules that will work like a charm... and they arent that expensive
