Dies When I Let Off the Gas
Old Jan 15, 2007 | 09:56 AM
tbchick's Avatar
tbchick
Default Dies When I Let Off the Gas
Have 96 2500 with the 5.9L and having a small problem. It starts and Idles fine but lately it has been getting worse. It ocasionally will die when I let off the gas pedal but yesterday it would not even stay running idle. Other than that it runs great when it is running. The only time it has ever done it is when it has been sitting cold motor.Even if Ilet it idle for 15 miniutesit will die soon as I let off the gas pedal.
Any suggesetion would be great.
Old Jan 15, 2007 | 12:19 PM
hilliad's Avatar
hilliad
Default RE: Dies When I Let Off the Gas
Could be the IAC valve. They get all gunked up up sometimes. You can take it off and clean up good with some throttle body cleaner.
Old Jan 15, 2007 | 01:59 PM
JarheadX's Avatar
JarheadX
that happens to me when i let my batt. get to low, like if i leave my amp on and don't drive for like 2 days.
Old Jan 15, 2007 | 02:33 PM
steve05ram360's Avatar
steve05ram360
yank off your TB and clean it and the IAC real good... 99% of the time this is the cause of the problem.
Old Jan 15, 2007 | 04:24 PM
Dodge4x4810's Avatar
Dodge4x4810
A bad battery can cause that. When i did my ball joints, i left the key in the on position the whole time and forgot about it. It drained the battery and i had to jump start it. It never ran right until i did a slow charge on the battery.
Old Jan 15, 2007 | 06:29 PM
metlhed01's Avatar
metlhed01
mine did that, exactly what you were describing.
ended up being the coolant temp sensor of all things. good luck
Old Jan 16, 2007 | 12:51 AM
Socha_62's Avatar
Socha_62
1. Dirty IAC
2. Weak battery/bad connections - Could be caused by a dying alt, but probably just dirty connections
Old Jan 16, 2007 | 02:43 AM
20dodgeram01's Avatar
20dodgeram01
could adjust your throttle cable too..
