how in the hell
Old Jan 15, 2007 | 05:04 PM
baltimore's Avatar
baltimore
Default how in the hell
how in the hell do you guys get to the distributer cap and rotor bottun? is it easy for you, or am i retarded?
Old Jan 15, 2007 | 05:25 PM
padodgeram's Avatar
padodgeram
Default RE: how in the hell
Its not the easiest job to do ..How i did it was take off the air cleaner gives a little more room.
Old Jan 15, 2007 | 05:27 PM
Joshwfl's Avatar
Joshwfl
What exactly is the problem you're having? I swapped mine out in 30 min.
Old Jan 15, 2007 | 05:38 PM
Japoro's Avatar
Japoro
It does take some work, but is manageable. With the air cleaner and ducting off, it becomes more visible. I ended up kind of sitting on the radiator when changing mine out this past weekend. There are two Phillip screws on each side that were a pain to get at till I just used a 9/32 socket to get to them.
Old Jan 15, 2007 | 06:08 PM
baltimore's Avatar
baltimore
i am haveing trouble reaching it, i have the screws off but now there is alot of tubes and wires in the way. i changed my plugs and they were worn down to way more then a 40 gap. so i am thinkin the cap and button are they same way
Old Jan 15, 2007 | 06:20 PM
baltimore's Avatar
baltimore
damn it man. ok i got it, but i felt like the cool-aid guy trying to fit through a doggie door. just as i thought the cap and button have alot of build-up from arcing. thanks guys, you can do it then so can i
Old Jan 15, 2007 | 07:16 PM
Ram1500Dodge's Avatar
Ram1500Dodge
3 inch bodylift makes it ALOT easier
Old Jan 15, 2007 | 07:48 PM
baltimore's Avatar
baltimore
my last post was at 3:20, it is now 4:47, that is how long it took me to get every thing back together
thanks guys
Old Jan 20, 2007 | 02:05 PM
TommysToy's Avatar
TommysToy
ORIGINAL: baltimore
[8D] LMAO @ the cool-aid man.
