Accel vs. K&N
RE: Accel vs. K&N
ORIGINAL: sciroccotune
studies have showen that foam lest in more unwanted stuff to teh inlet. there is even debate as to if cotton is better than paper but fome is down there with metal mesh filters. That said i know many people that have run foam filters for many many miles so i doubt you will notice any problems but i would recomend oiling the foam also.
Now, K&N does in fact make little air filters for our rc cars, and yes they look cool, but are the ABSOLUTE WORST you can buy. They let waaay too much in, and with those filters in dirt, you're very lucky to get 1 gallon on a big-block.
But, the foam filters attract a lot of dirt, especially with the filter oil, so you have to clean them usually every run or two while out at the track.
Now, I understand that real cars, and these rc cars are waaay different...(I could tell you anything and everything about rc cars and how they work, but dodge rams...not so much, lol.)
So I'm guessing that if foam filters really are as bad as you say, then the foam they use on cars isn't has fine, and is more pourous than on our rc filters...
RE: Accel vs. K&N
Some Duramax diesel owners did a very complete test
using the SAE laboratory tests
on how various air filters did...both for filtering and for flow restriction.
The website is now offline, but the old webpages are in Google's Internet Archive at:
http://web.archive.org/web/200412082...011/SPICER.htm
Even if you skip all the words
and just look at the pictures and graphs
you can learn a vast amount about air filters
at the above link
at the above link
