Truck is C-O-L-D Brrrrrrr
ORIGINAL: Rick3464
the one thing no one has touched on, is the most obvious to me. pop the hood turn on the heat and see if the A/C is on. my 01 has this issue, but i deal with it. the a/c shouldn't be on with the heat.it's good to mix the two, but it dramaticly cuts down on your heating.
I don't believe the 1997 Dodge trucks are designed for the A/C to come on with the heat or the defroster.
When I was in Alaska had a newbe try to run straight antifreeze. He called me up said his truck was froze. I went over and poped the cap it looked like a lime snowconein there. I told him you got to have water to activate the stuff. Towed him to the craft shop on post drained out about half and put in some water. While we were at it put in syn gear oil.
The A/C turns on with the defrosterbecause it dries the air out. Remember in the summer when there is a pool of water under your vehicle when you are running the air conditioning? The moisture is removed from the air when run through the evaporator unit. Assuming you have your heat turned up, the air is then heated back up by the heater core. This warm, dry air is much more effective at removing the moisture (fog) from you windshield.
