View Poll Results: A poll
msd 6a
50.00%
msd 6al
16.67%
msd offroad
33.33%
Voters: 6. You may not vote on this poll
which msd box
Old Jan 19, 2007 | 01:30 AM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: which msd box
Couple more questions:
What plugs can you/should you run with this ignition?
What gap?
Any special cap and rotor needed?
What coil is the best to go with this ignition?
Any minimum requirements on battery size?
Old Jan 19, 2007 | 01:37 AM
shott8283's Avatar
shott8283
i mean this with the upmost.. blaster3.. mainly b/c the PCM is picky when it comes to its coil.. if the PCM "sees" a lower or higher resistance to the coil.. she throws a fit and gets mad.. the blaster 3 is the best matched up to the stock coils resistance input...
i run autolite (-1 heat range then stock) and gap them to .40.. IIRC the stock is from .30 to .35 and also IIRC me , RMindy, and steve and a good convo going on what the best spark is.. for the added spark from the 6A and coil combo i stuck with .40 gap.. i play around with it sometimes but .40 has been the best for me.. obviously Indy's situation is a weee bit different then ours .. lol
hopes this helps silver!
Old Jan 19, 2007 | 02:07 AM
timwag2001's Avatar
timwag2001
if the resistance is so close with the blaster 3 do you still need to install the resistor that they recommend you buy with it?
Old Jan 19, 2007 | 02:08 AM
shott8283's Avatar
shott8283
that must be a new"er" model.. the blaster3 i put in didnt have any directions stating a aux resistor.. mines straight wired with no problems.. thats why i picked the 3 b/c it was best matched to the resistance.
Old Jan 19, 2007 | 02:14 AM
timwag2001's Avatar
timwag2001
im sorry, i think i was thinking about the off road coil.
do you go off road at all shott?
Old Jan 19, 2007 | 02:20 AM
RM_Indy's Avatar
RM_Indy
Recommended coil
6a and 6al is the regular blaster coil
The digital 6 is the blaster hvc coil
The digital 7 is the blaster hvc II coil
Lookingat the hvc II coils description though they recommend it for any msd 6 ignition so seems like any coilyou choose will be better than stock
NA on my mild 360 I was running .045 gap with the digital 6+, blaster coil and taylor 8mm wires. Ive run Bosch plats (not +2 or +4/crap) for the longest time and had the NGKs for a little while. With the 360 blown, Auto Lite 3923s with .035 gap. Probably reduce it to .030 when Ioverdrive the blower.
Personally I wouldnt run a gap over .050 if NA.
Old Jan 19, 2007 | 04:19 PM
Silver_Dodge
I was really wanting to do this mod, but the thought of having to go through the hassle of replacing the cap and rotor more often then I already do is making me rethink it. It is such a pain to get access to the cap if you don't have a body lift.
Old Jan 19, 2007 | 06:44 PM
shott8283's Avatar
shott8283
ORIGINAL: timwag2001
no comment [:'(][:'(][:'(]
lol.. yes and no.. i really dont haveanywhere to go OR'ing except my driveway when it rains.. regardless of my time constrants . so.. no not really.. man i suck
silver.. dude just get a 2" BL.. problem solved.. you know you wanna go bigger.
Old Jan 19, 2007 | 07:03 PM
Silver_Dodge
I called MSD about my questions, and they said:
For plugs, they said to keep my current 3923's. They said the cooler temp range will be a good thing. They said I should just gap them wider, like .045 or .050.
They said to go with the Blaster 2 or the Blaster SS coil. Anyone using one of these?
They could not say if I would go through caps faster, but it sounds like I probably will. This is a down side to me, and is making me think twice about this mod. Plus, I have the added expense of also needing new wires. If I do get one though, I think I am going to get the Offroad box. It does cost more, but I like the piece of mind that it won't have problems when I am up in the mountains or when I get snow up in my engine bay like I have done several times this year due to the blizzards.
Shott,
I was already wanting to get a BL anyway but I have concerns about it because it decreases the amount of weight you can safely put in the bed. I am still going bigger though, by just a little bit. I am going to change my 2" coils out for 3" coils. That will hold me until the next time I am ready to buy tires, then I will go up some more depending on what size tire I want to buy. 3" is about as big as I want to go with 285's. Much more, and the tires will look to small.
