Old Aug 5, 2015, 12:28 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: 4WD
Print Wikipost
4- Wheel Drive In Reverse
Old Jan 19, 2007 | 02:01 AM
  #21
Ram_Sport's Avatar
Ram_Sport
Default RE: 4- Wheel Drive In Reverse
well done, yea i wish i had limited slip, one wheel peels suck...
Old Jan 19, 2007 | 02:16 AM
  #22
Socha_62's Avatar
Socha_62
You betcha I am, started Tuesday. Its actually good to be back
Old Jan 19, 2007 | 11:24 AM
  #23
MiaTurbo's Avatar
MiaTurbo
ORIGINAL: Socha_62
ORIGINAL: red9535
just remember you cant turn very much, if at all, while your in 4 wheel drive, without risking serious damage.. so it probably wouldnt be a good idea.
Thats not true at all unless your shafts and u joints are made of plastic...
You can turn while in 4wd on any surface, although it does cause binding in the front the more traction you have. So on dry pavement it causes a good amount ot binding in the u-joints, but thats it. I really doubt you'd break one unless you had it at full lock and floored it.
People wheel Dana 44's with 37" tires which is huge forces on the shaft and joint and generally don't have a problem, except in extreme conditions.
Its a common myth for (no offence red9535) uneducated people to think they're going to screw up the diff or transfer case by taking a sharp turn on something like dry pavement. Its not really good for it, but the binding is caused at the axle u-joint.
The computer doesn;t control anything in teh differential either. Whether your in 2wd, 4hi or 4lo your diffs are totally seperate. The front is an open carrier, meaning the tire with the least resistance gets the power. So if one tires on pavement, and the others on ice, the one on ice will spin all day long and the one on pavement won't help at all.
The rear however usually has Limited Slip in the rear, which uses clutches to try to give both wheels power, but in severe differences in traction, like on wheel on tghe ground, one in the air, the clutches don't have enough stregnth to lock together, so the one on the air will spin and the one of the ground will hardly do anything.
A locked differential completely locks both sides together, no matter what. One can be in the air, one in a mud pit and both wheels will spin the same speed. There are full time lockers and selectable lockers which can be turned off, and when they're off they act like an open diff.
Anyways, going in reverse it totally fine. Also your diffs don't change in 2wd, 4hi, or 4lo.
pretty much what I was going to say...
Old Jan 19, 2007 | 12:07 PM
  #24
red9535's Avatar
red9535
Interesting. I had a basic understanding of it, but thanks for clearing up a lot of my confusion. Learn something new every day, right? I definitely dont claim to be an expert on everything when it comes to my truck
However, one thing I am going to have to disagree on is that regardless of if you are on wet or dry pavement.. Either surface has MORE then enough traction to easily do damage if your not careful when driving in 4x4. I'd definitely still warn the OP against driving around in 4 wheel drive, because of the cripple it puts on your turning abilities. Reverse is fine, though.. It all comes down to being careful.
Old Jan 19, 2007 | 03:53 PM
  #25
Socha_62's Avatar
Socha_62
I can damage stuff but like I said all its gonna be in the u joint or shaft, which would still suck.
I don't ever drive on dry pavement in 4, but really the worst case senario is that you'd break a u-joint or a shaft. And that'd be hard to do without trying to do it.
Glad you learned something, I thought the same things you did years ago. Learn something every day!
Old Jan 19, 2007 | 05:13 PM
  #26
Tani1500's Avatar
Tani1500
wtf thats the stupidest thing ive ever heard. if i couldnt use 4wd in reverse i would still be stuck in the woods from months ago[&:]
Old Jan 19, 2007 | 06:37 PM
  #27
red9535's Avatar
red9535
Well sure you CAN.. but that doesnt make it a good idea. CAN you throw your truck into neutral, rev the engine up to 6000 RPMs and then drop it into 1st? Sure.. but its obviously not a good idea and if it could possilby do serious damage to your truck.. why would you risk it?
Old Jan 19, 2007 | 08:28 PM
  #28
TMS Bill's Avatar
TMS Bill
There is no difference between reverse and forward while in 4by. I've seen guys back up a hill when they couldn't do it going forward. More weight over the (now) "rear" wheels for better traction.
Man ... who thinks this stuff up??
Old Jan 19, 2007 | 08:48 PM
  #29
dhvaughan's Avatar
dhvaughan
i think your 'guy at work' was just jerking your chain....he's probably still laughing.
when a friend of mine's daughter was about 6 or so she wanted a cat. frank told her they couldn't have a cat because they had electric heat. she said 'oh ok' and believed it for years.
Old Jan 19, 2007 | 10:05 PM
  #30
MiaTurbo's Avatar
MiaTurbo
And learning is half the battle! GO JOE!
