cluster or bcm?
Old Jan 19, 2007 | 12:57 AM
hcurry7968's Avatar
hcurry7968
Default cluster or bcm?
I have a 00 Ram w/ 5.9. My question is this, when start vehicle the ABS & air bag light come on, wait 10 to 15 seconds then the odometer flashes and the service engine (MIL) comes on, the odometer says "no Bus" and compass only says ccd, then the gas light comes on, none of the gauges work. This happened about 3 weeks ago, lasted for a few days then went back to normal. Last Friday same thing has happened. I have done the self check for ip cluster and the cluster works, so I am thinking bcm. Anyone out here have this problem before.
Thanks
Old Jan 19, 2007 | 01:24 AM
shott8283's Avatar
shott8283
Default RE: cluster or bcm?
this also happens when you program the PCM with a tuner like hypertech through the diag port right under the dash. wouldnt hurt to make sure that theres no garbage stuck in that harness.. its located (as your sitting in the drivers seat) to the right side of your right leg.. bout shin high. mounted right underneath the lowest point of the dash... almost right under where the ashtray/change/catch all tray opens.
if its good.. then id try reseting the pcm.. to reset.. pull the neg. batt cable of the batt. ,, put the key into the ignition rotate it to START and hold it to START for 30+ seconds.. release it and replace the neg batt cable. this will reset the PCM to factory settings.. if this doesnt help it. your PCM might be getting toasted.
did you install any kind of aftermarket coil to your ignition system by any chance?
Old Jan 19, 2007 | 01:37 AM
hcurry7968's Avatar
hcurry7968
I do have an aftermarket remote start/keyless entry installed. Condition has happened after use, but have had the system installed for about 2 years no other problems have occurred though.
Old Jan 19, 2007 | 01:39 AM
shott8283's Avatar
shott8283
ok. so this dash lights going bonkers happens after you use the RS function? (just trying to get that straight)
regardlesss.. wouldnt hurt to reset the pcm and trick it into relearning the truck..
Old Jan 19, 2007 | 01:51 AM
hcurry7968's Avatar
hcurry7968
this condition happened first about 3 weeks ago, stayed this way using r/s and with key, then went back to normal. condition returned last friday pm and has stayed with every start with r/s and with key.
Old Jan 19, 2007 | 01:52 AM
shott8283's Avatar
shott8283
thats really weird.. try what i posted above.. post back what you find out
(10mm wrench takes off the batt cable)
Old Jan 19, 2007 | 02:44 AM
dishdude2k's Avatar
dishdude2k
cut the wire for the tach sensor (coil sensor) on the remote start.. do it to where you can put it back on if needed.. alot of crappy remote starts will after time .. feed some voltage back into the coil where its not supposed to be.. not sure of the results.. but im sure it cant be good.. might just be something as simple as that ( with the weather changes.. gettin cold like it has all over.. its not good on any electrical circuit.. could have killed.. or is killing the remote start)
Old Apr 14, 2007 | 02:43 PM
hcurry7968's Avatar
hcurry7968
Finally broke down and took truck into dealer, they totally disconnected the aftermartket remote start, and guess what, the dash started to work correctly.
Glad its fixed but miss my remote start/keyless entry
Thanks
