Squeak Pop. Pop
Ok, so it was liek 0F this morning, and not only did the truck MOAN when i put it in drive i noticed two things. My clutch fan squeaks, and there's a popping/crackling sound from the passenger side of the engine in radom intervals, doesn't seem like spark knock.
i had a 97 318 that had the clutch fansqueak the idler pully bearing was going causing the pulley on the water pump to vibrate. next thing i know no more squeak and no more water pump. as far as the popping noise could be something shorting out. any codes?
