wired noise on accelerating
Old Jan 27, 2007 | 12:47 AM
97Ram2500's Avatar
97Ram2500
Default wired noise on accelerating
When I am first starting out from the truck sitting long enough for the engine to get cold, the engine is really loud alomst sounds like a large fan going really fast. The noise increases with engine speed and after usually 2 shifts the noise goes away and everything sounds normal. I have tried letting the truck sit running for a couple of mins to make sure the oil has warmed up a little. I have a 360 with an auto trans with about 250,000 miles and the tranny was just rebuilt(all fluids are topped off), I just changed the oil to Shell 15w40 since I read it will help with compression on high mileage engines. I also am using valvoline full synthetic ATF+4 for the tranny. Any ideas what this is and if it is harmful or just annoying?
Old Jan 27, 2007 | 01:04 AM
superdak05's Avatar
superdak05
Default RE: wired noise on accelerating
thats what they call your clutch fan. it will do that untill it reaches optimal speed. dont worry i have an 05 4.7 dak that does it everytime i take of in the morning wether it is 0 outside or 80 outside.
