question on rear end
Old Jan 27, 2007 | 09:58 PM
rollerstud98's Avatar
rollerstud98
Default question on rear end
how do i know what gears i have in mine, i blew the pinion gear up haha so now i need to replace that, i have 2 little tags with the numbers 2528 on one and 35 on the other
Old Jan 27, 2007 | 10:02 PM
Sirhilton17's Avatar
Sirhilton17
Default RE: question on rear end
Mine has the same tag, I have 3.55 gears...
If you wanted to be 100% sure, email dodge and ask for a build sheet, I did and it said what gears, what differentials, everything...
Old Jan 27, 2007 | 10:07 PM
rollerstud98
alright thanks, i'm thinking i probably have the 3.55's to though,
Old Jan 27, 2007 | 10:34 PM
Chopper1's Avatar
Chopper1
the tag under the front edge of the hood might have the info...
Old Jan 28, 2007 | 12:49 AM
SnoPro Dodge's Avatar
SnoPro Dodge
Pull the diff cover. There are numbers stamped into the ring gear, should be a date code then gear numbers. Divide the ring gear teeth by pinion teeth. example 41R/10P=4.10 ratio.
Old Jan 28, 2007 | 02:04 AM
rollerstud98
yeah i pulled the cover off earlier and had 2 big chunks of the pinion sitting in the bottom of the diff, i'll look into it more next week hopefully, good thing i have 2 trucks though or i'd be driving my work van with no radio
