WOT wont shift?
Old Jan 31, 2007 | 10:23 PM
IndyRamMan's Avatar
IndyRamMan
Default WOT wont shift?
Sometimes when Im WOT through first, it will bounce off the rev limiter untill i let off the gas. obviously i dont let it bounce more than once, but what do you think that could be a result of? Thats not normal for these trucks, is it?
Old Jan 31, 2007 | 10:25 PM
pashtrd's Avatar
pashtrd
Default RE: WOT wont shift?
not sure if it's normal but mine does the same thing. 2001 Ram w/360
Old Jan 31, 2007 | 10:26 PM
TMS Bill's Avatar
TMS Bill
Do the TV cable adjustment ... sounds like you're badly in need of it.
Old Jan 31, 2007 | 10:29 PM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: TMS Bill
is it like chevys are?
do a search, yea?
Old Jan 31, 2007 | 10:54 PM
TMS Bill's Avatar
TMS Bill
Never did one on a Chevy ... actually ... Dodge either ... mine works fine. Look in the FSM.
You DID get the FSM, didn't you?
Old Feb 1, 2007 | 02:34 AM
timwag2001's Avatar
timwag2001
ive never hit the limiter but i red line
Old Feb 2, 2007 | 01:16 AM
User's Avatar
User
http://www.bionicdodge.com/Download/Dodge_Ram_Truck_Transmission_Adjustment.pdf
mine does the same thing, except its from 2nd to 3rd. Ive herd alot of thing, TV Cable, Govenor Pressure Sensor (GPS), Govenor Pressure solinoid, Tranny Bands, Links ect...
When i adjusted my TV cable it didnt fix the problem, but ti did notice a diffrence in tranny shifts.
They say the problem with the GPS is when you have alot of power units going it sends the wrong voltage to it, and it doesnt shift right, i read right, and you need to replace the GPS. Its about 50 dollars, and the solinoid is a bit cheaper.. when i get a job thats my next project, i cant stand it anymore.
Old Feb 2, 2007 | 01:56 AM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: TMS Bill
and the memo too.
Old Feb 2, 2007 | 01:59 PM
TMS Bill's Avatar
TMS Bill
Yeahhhhh ... lemme send you a copy of that ...
User2006 posted an EXCELLENT how-to on the TV cable adjustment. May or may not fix the problem but it's a good place to start and very easy to perform.
Old Feb 2, 2007 | 05:43 PM
jbfire's Avatar
jbfire
heres a link about the governor pressure sensor. its for a jeep but has the same concept. its tells you how it works and what other possibilites your problem could be. hope it helps because i have the same problem .
http://www.asashop.org/autoinc/july98/techtips.htm
