Gauge Bezel?
Easy. Justreplaced my stereo and cleaned out the dirt in the inst. cluster.
First, set the parking brake, and put your tranny in 1st gear (disregard if you have a manual tranny). Tilt the steering wheel all the way down.
Second, open the cup holder, remove the two screws holding it in and remove the cup holder assembly.
Third, open the ashtray, remove the two screws and remove it as an assembly.
Pull the trim piece out, starting near the cup holder. Should pull out pretty easy. Remove the 12volt outlet wiring plug and cigarette lighter wiring plug as they become accessable.
I believe there are 6 brass colored screws holding the plexiglass covering the cluster. Remove those, pull off the plexiglass, and install your bezel. I don't think you would need to remove the cluster.
Should take you less than a half hour if you know which end of the screw driver to use - it's really that simple.
Where did you get the bezel? Show a pic after it's installed. I want one, but I'm not sure if I like the aluminum look. A friend of mine has a Rumble Bee and he put in a yellow bezel. Looks really good.
