O2 SENSORS
Old Feb 7, 2007 | 03:02 AM
Zachtk8702's Avatar
Zachtk8702
Default O2 SENSORS
Im planning on redoing my exhaust system...
What im thinking about doing is this...
Cut off the cat...
Install an X pipe
http://www.autoanything.com/exhausts...A2672A0A0.aspx
And this magnaflow exhaust
http://store.summitracing.com/partde...p;autoview=sku
I'm thinking this will sound pretty good, Im driving a 2001 Dodge Ram 1500 5.9L 360
I need to know if there are any o2 sensors behind the cat... Otherwise I cant cut it off...
Old Feb 7, 2007 | 04:05 AM
radwebster's Avatar
radwebster
Default RE: O2 SENSORS
ORIGINAL: Zachtk8702
besides the fact that you could easily look for youself in 10 seconds...
yes theres one behind the cat. removng it wont affect anything but it will through a check engine light, so you can get an O2 sim or just weld an O2 sensor bung into the new pipe after the cat
Old Feb 7, 2007 | 02:03 PM
Zachtk8702's Avatar
Zachtk8702
So an o2 sim is something I would just plug in where the old o2 sensor went??? and it tells it its getting a good reading.....
Old Feb 7, 2007 | 02:25 PM
zique's Avatar
zique
yes.
Old Feb 7, 2007 | 02:43 PM
Zachtk8702's Avatar
Zachtk8702
Inresting... Thanks!
Old Feb 8, 2007 | 01:58 AM
Zachtk8702's Avatar
Zachtk8702
Anyone know where I can locate one of these o2 sims.....
Old Feb 8, 2007 | 02:18 AM
SnoPro Dodge's Avatar
SnoPro Dodge
Fastman. The guy that does the Throttle body mods.
Old Feb 8, 2007 | 03:09 AM
shnormo's Avatar
shnormo
If your computer is a smarter version, it won't like the O2 simulators because it can do a system cycle check to see if the voltage cycles with it. And yes it does affect your gas milage if you don't have a downstream O2 sensor. Summitracing is the easiest place to find an O2 simulator.
Old Feb 8, 2007 | 05:48 AM
Zachtk8702's Avatar
Zachtk8702
how does it effect gas milage?
