1st gear shifts?
Old Feb 10, 2007 | 04:00 AM
jbfire's Avatar
jbfire
Default 1st gear shifts?
i am curious about what controls the 1-2 gear shifts? when i am stoped and pin it, it wont shift out of first. only when i let off it will then shift. also it seems like first gear at regular driving revs up for no reason. when i am driving normal it will still rev up to 2500- 3000rpm for no reason. does anyone elses do this. i have read alot of forums about what to look for. i have done a tv cable adjustment and have seen alot on the governor pressure solenoid and the speed sensor going bad. what do you guys think????
Old Feb 10, 2007 | 01:43 PM
dsertdog56's Avatar
dsertdog56
Default RE: 1st gear shifts?
I'd start by adjusting the TV cable...
http://www.v8performance.com/tipsandtricks.htm#TVCable
Old Feb 10, 2007 | 06:00 PM
jbfire's Avatar
jbfire
like i said in the first post i allready did the tv cable adjustment. i have heard about the govenor pressure solenoid and the speed senor going bad. not sure what else i should check or what to check first?
thanks
Old Feb 10, 2007 | 06:10 PM
mattyge's Avatar
mattyge
mine does the same thing only with 2nd gear. i took it too the tranny shop they said rebuild like i thought they would. still haven't figured it out.
Old Feb 11, 2007 | 02:07 AM
kingofnothing14's Avatar
kingofnothing14
i was having the same problem with mine it didn't want to shift from 1st to 2nd, but then shifted thru the rest of the gears just fine...tranny guys said it was the solenoid...of course my O/D was blown too, so i had to rebuild
