Specifications for 1995 Ram 1500 SLT w/5.9?
Old Feb 11, 2007 | 08:29 PM
raynist's Avatar
raynist
Default Specifications for 1995 Ram 1500 SLT w/5.9?
Hi,
I am trying to find information regarding HP and TQ for this vehicle. I am purchasing it tomorrow.
I would also like to know if anyone knows the vehicle weight, rear end ratio options and transmission gear ratio's and compression ratio and gas tank size.
Also, what is reasonable MPG estimates for city and highway driving?
Thanks!
Ray Nist
Old Feb 12, 2007 | 10:07 AM
HankL's Avatar
HankL
Default RE: Specifications for 1995 Ram 1500 SLT w/5.9?
http://dodgeram.org/tech/gas/specs/index.html
warning: the torque graph in the above specs is reversed and its right side should be its left. This means the torque shown at high rpm is actually the torque at low rpm.
Hp curve is ok.
Average MPG for a 1995 4x4 5.9V8 46RH auto trans 3.55 diff
should be about 12 in mixed driving,
maximum highway is about 20 at steady 60 mph on level windless interstate,
but drops to about 14 MPG at 79 mph, even less with big 'mudder' tires
Check out the TSB (technical service bulletins) for your year at:
http://dodgeram.info/tsb/1995-index.htm
Also look over the new buyers checklist:
http://dodgeram.org/buying_info/Inspect.htm
Old Feb 13, 2007 | 02:16 PM
raynist's Avatar
raynist
Thanks for the info.
Where there other rear end ratio options? My truck has 265/75/16 tires and the rpms at 60 MPH is only 1500. Seems pretty low.
--Ray
Old Feb 13, 2007 | 02:58 PM
HankL's Avatar
HankL
3.92 was a factory available option
today 4.10 & 4.56 and at least one supplier of 4.88 are sold,
but the 9.25 differential has been plagued by
bad pinion seals
bad pinion bearings
and breaking lsd clips
so when spending money on the rear differential
it is best to upgrade to the Dana 60 that was available on some
2500 Rams and prior year 250 Ram vans.
Old Feb 13, 2007 | 08:25 PM
junkman306's Avatar
junkman306
Pop the hood and look at the sticker on the underside of the hood. It will give you all the options codes and tell you the rear end ratio also.
Old Feb 14, 2007 | 11:51 AM
HankL's Avatar
HankL
You can get a 'build sheet' directly from Chrysler for your truck at this website.
They email you a 2-3 page sheet with all the specific parts on your truck.
In the
"Briefly describe" box
write that you need a build sheet for your vehicle so that you can correctly find maintenance parts
http://www-5.dodge.com/wccsapp/unive...amp;category=R
Old Feb 14, 2007 | 03:41 PM
1969roadrunner's Avatar
1969roadrunner
According to my window sticker, my '97 5.2only makes 220hp, not the 230 listed on Geno's...
Oh, and Ray, with those size tires and those RPMs, it sounds like you have the 3.55s...
Old Feb 14, 2007 | 04:14 PM
TPSDODGE's Avatar
TPSDODGE
if you want to know for sure pm me with your vin and i will email you a build sheet (i work for a dealership)
