Shift kit
Old Feb 14, 2007 | 08:24 PM
jscherencel's Avatar
jscherencel
Default Shift kit
Where did you guys get you shift kits at? I've got a 46re and I'm buying one but I don't know where's the best place to buy. The only place I found is ... http://www.transmissionpartsusa.com/...00%2D00054931B
Old Feb 14, 2007 | 09:02 PM
TPSDODGE's Avatar
TPSDODGE
Default RE: Shift kit
dont do it.......you'll be rebuilding in month if you try to use a shift kit in a 46re the planataries aren't stout enough for even normal use maybe if you rebuilt your 46re with 48re parts then you would be ok
Old Feb 14, 2007 | 11:55 PM
jscherencel
I did have my tranny rebuilt about 10,000 miles ago.Would that make a difference (low miles on rebuild)? I know the mechanic used only 46re parts.I'm just trying to make the tranny stronger andlast longer, i do realize that the trannys are terrible. I also change my fluids and adjust the bands on a regular basis.
Old Feb 15, 2007 | 12:16 AM
TPSDODGE's Avatar
TPSDODGE
your best bet is to leave the tranny alone and add a extra cooler
Old Feb 15, 2007 | 01:49 AM
Terran's Avatar
Terran
Well i'm not sure i'd adgree with TPS, a good shift kit will firm up the shifts without making them harsh, and prolong the life of the transmission.
Old Feb 15, 2007 | 04:06 AM
radwebster's Avatar
radwebster
ORIGINAL: Terran
this is correct. an APS shift kit will significantly strengthen and prolong the life of the trans.
faster, firmer shifts means less slippage and less heat.
