Got towed
Old Feb 16, 2007 | 05:08 AM
Cereal Killer's Avatar
Cereal Killer
Default RE: Got towed
That sounds a hell of alot cooler than sellin it.
Old Feb 16, 2007 | 05:13 AM
radwebster's Avatar
radwebster
ORIGINAL: habeba86
Well it was the bearing...he said it was almost seized up. It didnt take anything else with it...I guess I was jst paranoid about the brakes....and I was half in snow...idk Ill notice if its weird when I drive it tommarow. Should I get the driverside done also...is it gona be close to going out if the other one did? I would rather do it now, then have it go out in a bit...
i didnt doubt it was a bearing. if you havent had then changed in a while, i would replace both unit bearings. keep the side that is still good though, in case another one ever goes bad on you.
when the bearing starts going bad, it will sit off center, which will make the truck pull to the side of the bad bearing. when you apply the brake, even slightly, you will recenter the bearing and it may roll ok...all of this leads to an interesting brake feel, which may lead you to be;lieve your brakes are bad.
at least it didnt fail totally on you.
Old Feb 16, 2007 | 05:23 AM
habeba86's Avatar
habeba86
Ya...I have come to the conclusion I can never sell this truck.....ever. It's too badass....specially once I finally lift it. Thanx for all the info and tips rad.....btw, I hope you make it out alive over ther at pirate
