Front Suspension Repair
Old Feb 15, 2007 | 02:38 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Default Front Suspension Repair
I know the tie rod ends are worn on my truck and warrant replacement. The pivots for the drag-link are most likely worn as well after 124K miles. I am debating on replacing everything between the front wheels, including the pitman arm. The one item I am undecided on are the ball joints. I know that if I replace everything that the truck will need an alignment. My dilemma is whether I replace everything and get it aligned, or take all of the parts to a shop and let them do it.
Most of you know that working on my truck doesn't scare me; however, I am looking at how long it will take to accomplish the task.
Any and all advice/opinions are welcome.
Old Feb 15, 2007 | 03:39 PM
damageddakota's Avatar
damageddakota
Default RE: Front Suspension Repair
all that stuff is easy if you have a pickle. do them one at a time and count how many times you turn it to get it off and spin the new one on the same, you will be suprised how easy this is and that you can get everything real close to where it was. you will get raped if you take it in
Old Feb 15, 2007 | 03:41 PM
damageddakota
ps, it took me 3hrs to do everything between the wheels, but i have a car hoist
Old Feb 15, 2007 | 06:23 PM
capt joe's Avatar
capt joe
You will need an air chisel to replace ball joints, they are riveted in!
Old Feb 15, 2007 | 07:22 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: capt joe
Did not know that. Thanks!
Old Feb 15, 2007 | 11:57 PM
DieselDemon's Avatar
DieselDemon
ORIGINAL: capt joe
What year Ram are you talking about? What rivets?
Old Feb 16, 2007 | 12:41 AM
Tani1500's Avatar
Tani1500
ORIGINAL: DieselDemon
ORIGINAL: capt joe
i sec that? im confussed?
Old Feb 16, 2007 | 01:28 AM
focuz's Avatar
focuz
They are?
Old Feb 16, 2007 | 02:10 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
OK, it seems the remark about the ball joints being riveted in has taken many people for a loop. Is this a fact or not?
Last night I went to O'Reilly Auto Parts and ordered all front end parts (tie rod ends, drag link, pitman arm, rotors, pads) and 1-ton Chevy wheel cylinders. I forgot to get shocks, but I can cover my bases on that later. As long as I am going to have the front end apart I would like to get the ball-joints done. Is there any advice for this?
Old Feb 16, 2007 | 02:52 PM
padodgeram's Avatar
padodgeram
last i check there was a ring or C clip... NOT rivets.. I use a press ball joint press to pull em out and put em in...I guess you can use a hammer to ? i bet this so called "rivet" was the grease nipple this guy seen ? if that the cause then LOL !!!!
