Rough Engin Idle 5.9L
Old Feb 15, 2007 | 11:52 PM
Dutch114's Avatar
Dutch114
Default Rough Engin Idle 5.9L
I have developed a rough engine idle. It started this las weekend. The check engine light (the grand and usless tool) came on. When I ran the codes it came up as miss fire in #1 cylinder.I replaced the cap, rotor, plug wires,and checked the plugs.I had already put new plug and wires on it in July. Anyone got any ideas?
Old Feb 16, 2007 | 12:33 AM
spaz_22's Avatar
spaz_22
Default RE: Rough Engin Idle 5.9L
could be your fuel injectors as well. Does the code still come up? do a drive cycle and see if the code still comes up. Your iac motor could be gummed up too.
Old Feb 16, 2007 | 12:58 AM
Dutch114's Avatar
Dutch114
The light has not came back on sincecleared it sat. afternoon. I also had some carbon buildup on the butterflies in the throttle body. I cleaned that up and didn't really have any problems again till tonight. I might run some injector cleaner. and put a new plug in the #1 cylinder. I will also check the IAC motor.
Old Feb 16, 2007 | 01:35 AM
Dutch114's Avatar
Dutch114
Has anyone ever flushed the intake. I cant remeber what you call the stuff, but it comes in a can and you connect the line to the intake manifold. You run the engine until it sucks the contents of the can into the intake and chokes the motor. then you let it sit for a period of time. Anyone know what the call that stuff?
Old Feb 16, 2007 | 02:43 AM
padodgeram's Avatar
padodgeram
SEAFOAM >>>> http://www.seafoamsales.com/
Old Feb 22, 2007 | 02:59 AM
Dutch114's Avatar
Dutch114
I worked on the truck this weekend. I put new plugs, wires, distributor cap and rotor on the truck. I discovered that the #8 cylinder was fouled and the cap and rotor had some wear and corrosion. The best I can figure is that since #8 had a fouled plug, the spark was arking in the distributor and prematurely firing the #1 cylinder since it was next in the firing order.
Anyways, I still need to clean the intake. I think you are correct about sea foam, but where in the world can I get the stuff. Everyone I contact acts like I am asking for a pink elephant. I also can't find it anywhere on the net. I know I have bought the stuff before, any clues?
Old Feb 22, 2007 | 03:09 AM
padodgeram's Avatar
padodgeram
http://www.seafoamsales.com/buy.htm I got it at napa .. there the link to where to buy it...
Old Feb 22, 2007 | 03:49 AM
Dutch114's Avatar
Dutch114
Thanks, but I can't find it on any of the parts sites, when I enter sea foam in their search, it comes up with no matches found
Old Feb 22, 2007 | 03:55 AM
ShakyJay's Avatar
ShakyJay
They sell it at Pep Boys, AutoZone, Carquest, Napa etc. etc. Seems like you can get at almost any auto parts store you walk into.
Old Feb 22, 2007 | 03:58 AM
Dutch114's Avatar
Dutch114
I will just have to make a trip to one of the places i haven't tried yet, thanks
