4wd light
Old Feb 17, 2007 | 01:21 PM
quadro's Avatar
quadro
Default 4wd light
Do any of you guys have a problem with your 4wd light staying on after you take it out of 4wd? After the last storm that we finally got, my kight stayed on for the next two days. I know it wasnt in 4wd anymore. Its not a real big problem, I dont think its hurting anything, just wondered what the reason was
Old Feb 17, 2007 | 01:51 PM
tdmopar59's Avatar
tdmopar59
Default RE: 4wd light
it could be a bad sensor
Old Feb 17, 2007 | 07:25 PM
DieselDemon's Avatar
DieselDemon
It's a simple fix. Autozone sells the switch. It just screws in to replace the old one.
It's probably loaded up with salt and is stuck. Only other problem would be the actuator is up against the switch still.
Good luck with your ride.
