Transfer Case get oil from the tranny?
Old Feb 19, 2007 | 09:43 PM
dflyboy's Avatar
dflyboy
Default Transfer Case get oil from the tranny?
Hey I was wondering if the transfer case gets some oil from the Tranny, or if it is a totally self contained system. I have a leak outa the back of my transfer case where my drive shaft comes out so i am just curious.
Old Feb 19, 2007 | 09:46 PM
radwebster's Avatar
radwebster
Default RE: Transfer Case get oil from the tranny?
self contained, it uses ATF fluid also
also, the rear output seal is hella easy to change. pop the rear driveshaft out by pulling the ujoint caps off at the rear axle, and just slide it out of the t-case. the seal just yanks out, and push a new one in...rub some oil on the new seal, and slide the d-shaft back in. bolt it back up and you're done.
Old Feb 19, 2007 | 10:01 PM
dflyboy's Avatar
dflyboy
ok thanks.... I am about to crawl under it and check the fluid levels and fill it up, until i can fix it. And thanks for the quick lesson on how to change it out Radwebster, I appreciate it.
Old Feb 20, 2007 | 08:42 PM
TMS Bill's Avatar
TMS Bill
One thing (if you haven't done this yet) ... mark the driveshaft with a chalk line or dots or something (at the yoke) so it goes back together the same way it came apart (and not 180 out). The non-vibrating truck you save may be your own. [8D]
