update:what do you think of this product?
Old Feb 20, 2007 | 12:07 AM
vsraptor's Avatar
vsraptor
Default update:what do you think of this product?
I have a coolant leak somewhere on the back side of the motor. I've looked and looked. But i loose the trail as it goes up the side of the bell housing. It leaves a decent size wet spot in the drive way. I dont like to use quick fixes but........this will have to be an exception. My queston is what do you guys think of this product? Even though it is allready in the works. I need to know your opions. I took this product option on the word of the guys at local O'riellys.
http://www.k-seal.co.uk/INDEX3datasheetsealup.htm
Old Feb 20, 2007 | 01:04 AM
TPSDODGE's Avatar
TPSDODGE
Default RE: what do you think of this product?
no no no just fix the intake gasket where its leaking from the back where the intake meets the head
Old Feb 20, 2007 | 01:12 AM
shnormo's Avatar
shnormo
Quick fix, buy a new car.
Old Feb 20, 2007 | 01:28 AM
junkman306's Avatar
junkman306
That stuff works, but as bad as yours sounds i'd go get it fixed.
Old Feb 20, 2007 | 01:29 AM
radwebster's Avatar
radwebster
go ahead and add that, or any simliar product with copper in it. i've used it before with no problems and, my dads caprice has been running that last 10 years with a cracked head and a copper sealant in it. zero leaks.
if you do use it though, follow the instructions exactly, and DO NOT use more than one container. my old POS '84 corvette had coolant leaking from everywhere, so i fiugred if one bottle worked 6 would be even better [:'(]. oh it worked...sealed my heater core into a block of copper.
just use one container and it'll be fine
Old Feb 20, 2007 | 01:34 AM
whiteram00's Avatar
whiteram00
nah just fix it ,we use stuff like that at work,then the drivers are bitching at use cause they have no heat,an r running hot
Old Feb 25, 2007 | 02:10 AM
vsraptor's Avatar
vsraptor
updatek, i know it wasn't tge best idea but working six days a week out of town, i had to do a quick fix. The coolant leak was contained. So far so good.
