heater core
Old Feb 21, 2007 | 02:25 AM
scottybme's Avatar
scottybme
Default heater core
Is there anyone out there doing a heater core right now that has the airbag out?
Old Feb 22, 2007 | 12:32 PM
mojo's Avatar
mojo
Default RE: heater core
Just did mine don't worry about the airbag. You need to pull the whole dash the airbag can stay right there just unplug it. You need to drop the steering wheel and remove the bolts that hold the dash in place, if your skinny enough you can prop the dash with a bungee cord around the grab handle and remove the heatercore box but if your fat like me thengrab a buddy and pull the whole dash out of the truck. You didn't say what yr it was some boxes are bolted together some are glued if your's is glued you will have to brake it to get it appart.It's also a good time to look at the Evap core if the heater is bad the other is not far behined.There is a piece of plastic that seperates the two, it's over engenering, and the problem with it is thats what collects all the leaves and crap that falls between the cowel and rots the heater core out, you don't need it socan it. good luck!
Old Feb 22, 2007 | 01:20 PM
kikidbird's Avatar
kikidbird
I did mine last week, it seems like alot of work but it's not. You will be happy when you are putting on the dash, that it's all over. Don't forget to disconnect the battery.
