squeaky, any answers
Old Feb 21, 2007 | 08:08 PM
jlong's Avatar
jlong
Default squeaky, any answers
when my truck is in park or in idle i have a squeak from the belt or one of the parts that the belt rolls on, its a 94 dodge ram sport it has a new wp and alternator any ideas, thanks yall. john
Old Feb 21, 2007 | 08:10 PM
BradBeyer's Avatar
BradBeyer
Default RE: squeaky, any answers
you could replace the serpentine belt or the tensioner could be going bad...there is a product called belt dressing that will quit the squeak.
Brad
Old Feb 21, 2007 | 08:43 PM
TMS Bill's Avatar
TMS Bill
I'd suspect the belt tensioner... hit it with some WD-40 (the center and the joint) ... engine OFF.
Old Feb 21, 2007 | 09:30 PM
jlong's Avatar
jlong
thanks guys the belt is fairly new ill try some wd40 on the tensioner and the belt dressing hopefully that stuff wont turn it into a super high pitched squeak.
Old Feb 22, 2007 | 03:14 AM
Ganderguy's Avatar
Ganderguy
I had the same exact problem with mine a couple of weeks ago, changed the belt tensioner (about $60) and it is quiet as can be now.
There is actually a post on here that shows a step by step instruction.
Good luck
Old Feb 22, 2007 | 06:23 AM
topsites's Avatar
topsites
Be careful with the wd-40 so you don't get it on the belt, but it's a great trick.
I personally don't care much for belt dressing, thou I keep a can around for emergencies, it tends to do as much harm as good.
Old Feb 22, 2007 | 04:49 PM
jlong's Avatar
jlong
ok well i tried the wd40 trick and took the belt off and sprayed the bearing behind the roller and and the joint where it gets its tension from it stopped for a min with a light squeak and picked up again the tensioner seemed to be working fine, but its back and i dunno what it is maybe it could be just the belt cause it is a little shiny on the backside i have read it is not suppose to be shiny. maybe i will just have to replace the belt with a mopar belt. any suggestions what about the idler? thanks john
Old Feb 22, 2007 | 05:18 PM
radwebster's Avatar
radwebster
they have an item called a mechanics stethascope. instead of the pad on one side like the medical ones, it has a pointed rod. touch the rod to various parts under the hood while the engine is running, and you can figure out what pully is making the noise
Old Feb 22, 2007 | 08:06 PM
mattyge's Avatar
mattyge
idler pulley or tensioner i guess it's called usually goes around the same time as the water pump
Old Feb 22, 2007 | 10:22 PM
jlong's Avatar
jlong
well i tried the stethescope and didnt find anything abnormal i guess im going to have to replace the belt tensioner and pulley with some good ole mopar parts, and see if that helps, should my fan spin freely with the motor off? maybe its the clutch? thanks john
