95 ram ball joint intallation
Old Feb 22, 2007 | 01:15 AM
tonycowan's Avatar
tonycowan
Default 95 ram ball joint intallation
i am trying to replace lower and upper ball joints and i am trying to disengage the ball joints from the steering knuckle and i am unable to do so. the chilton manual is difficult to fully understand. anyone have any suggestions. tks
Old Feb 22, 2007 | 02:03 AM
nolazach's Avatar
nolazach
Default RE: 95 ram ball joint intallation
Download the Factory service manual from this site www.dodgeforum.com/m_340929/tm.htm
this is a lot better than the Chiton one.
To seperate the joint from the spindle you will need a breaker rent it from the Zone or buy it for like $10. I helped my buddy do a Spindle lift on a 96' and we were able to get the ball joints out with a press rented from Autozone. Free rental just put down a deposit. When I did mine I had a problem getting them out of the lower control arm. I took them off and brought them to a machine shop who charged me ten bucks to press them out and put the new ones in. Took him a few seconds. If you are having trouble this may be the way, I would try the press first.
Old Feb 22, 2007 | 02:06 AM
DieselDemon's Avatar
DieselDemon
You may want to put some heat to them before you attempt to press them out.
Get them hot and they pop right out like nothin'.
Good luck with your ride.
