QUESTION ABOUT SUSPENSION
Old Feb 22, 2007 | 11:42 PM
dirty dog's Avatar
dirty dog
Default QUESTION ABOUT SUSPENSION
ok guys i currently have a 5" rough country suspension lift and i am wanting to order the skyjacker 7" coils and dick cepek long arms. what will i have to change to go from a 5" to 7" coil in order to do this? i am trying to find out how expensive its going to be before i start ordering this stuff
Old Feb 23, 2007 | 12:43 AM
Ram1500Dodge's Avatar
Ram1500Dodge
Default RE: QUESTION ABOUT SUSPENSION
shocks maybe? im not sure how it will affect driveshaft angle, have you extended your brake lines?, any wires going to the front diff for 4x4.have you done a drop pitman arm? those kinda things?
Old Feb 23, 2007 | 12:51 AM
dirty dog's Avatar
dirty dog
i have the rough country kit. im guessing that is has a drop pitman arm but dont know if it is big enough and i know that the transfer case has been dropped. im going to get new shocks anyway but i was hoping that someone on here has upgraded a suspension before and that they could tell me what they had to do.
Old Feb 23, 2007 | 12:52 AM
dsertdog56's Avatar
dsertdog56
I'd be changing the trackbar, contact Thuren fabrication for it. You'll need a drop pittman arm and you might consider a better steering setup. Driveshaft angle, brake lines...seriously, I'd scope out some other web sites before doing this, theres a lot of things involved in doing this type of lift correctly/safely.
Old Feb 23, 2007 | 12:55 AM
dirty dog's Avatar
dirty dog
5" Suspension Kit includes:
[/align][ul][*]
Front coil springs
Upper and lower control arms
Sway bar drop brackets
Track bar drop bracket
Bump stops
Polyurethane bushings
4 RC Hydro 8000 series shocks
u-bolts
Rear blocks.
[/ul]
