fuel filter
Old Feb 23, 2007 | 05:00 PM
kyle k's Avatar
kyle k
Default fuel filter
i need some help here fellas.i have a 1998 dodge ram1500 5.2. i had some really bad sputtering going on in my truck, to the point where my truck was shaking a bit will driving. i took it in to my mecanic that knows my truck well and he first said the injectors were bad, so he cleaned them, put them back in and the problem with the sputtering after a little drive occured again. so he took the same injector out and it was very dirty again. then they said it has to be the fuel filters and figured out that ithas aNONSERVICEABLE fuel filter. i dont understand.can someone explain this.
Old Feb 23, 2007 | 05:07 PM
dropride's Avatar
dropride
Default RE: fuel filter
The fuel filter is part of the fuel pump module in the tank.
Old Feb 23, 2007 | 08:19 PM
TMS Bill's Avatar
TMS Bill
Clean your fuel rails.
Old Feb 24, 2007 | 09:47 AM
Dallas192's Avatar
Dallas192
check your intake manifold to see if the plenum gasket is leaking and sucking oil down the intake. That will clog the injectors quick......Dallas
Old Mar 13, 2007 | 03:58 PM
txbuck's Avatar
txbuck
What and where exactly are the fuel rails? Sorry, but I am having hte same probelm and my fuel pump is fairly new. But you can change the fuel filter without changing the entire fuel pump. correct?
Old Mar 13, 2007 | 04:03 PM
southgadawg74's Avatar
southgadawg74
The fuel filter is part of the fuel pump assembly which is in the gas tank...hence the nonservicable..if you just replaced the fuel pump then you have a new fuel filter as well. Have you had a general tune up?? Bad plugs can cause that sputtering as well. Mine was doing that. You'd get going and get about 55-60....and the truck would shake..almost like it was the tranny...but the plugs were bad. Just a suggestion.
Old Mar 13, 2007 | 05:01 PM
DuranguenzeRam's Avatar
DuranguenzeRam
have you checked the tps? mine was stuterring too changed tps good to go now
