Transmission oil cooler lines
Old Feb 24, 2007 | 02:24 PM
Rammer1500's Avatar
Rammer1500
Default Transmission oil cooler lines
If I replace one or both transmission flexible hoses that connect to the radiator, should I be concerned about air getting into the system, and approximately how much fluid would I lose?
Old Feb 24, 2007 | 05:15 PM
dhvaughan's Avatar
dhvaughan
Default RE: Transmission oil cooler lines
i just put on an extra cooler and had the lines loose. no worry of air, the pump will push it out. i lost about a 1qt from the trans cooler in the radiator. if you have an additional cooler, a little more will come out of that.
