Radio controls on steering wheel problem.
Old Feb 25, 2007 | 09:48 PM
traderjk's Avatar
traderjk
Default Radio controls on steering wheel problem.
I have a 2002 Dodge Ram 3500 w/ Cummins Diesel.
I have the remote radio controls on the steering wheel and the other day, they just stopped working. The radio/cd player and tape deck work and you can tune the radio and change stations etc. manually but not using the steering wheel controls. Is there a seperate fuse for that and if so, where is it???
Thanks.
Traderjk
Old Mar 9, 2007 | 04:29 AM
traderjk's Avatar
traderjk
Default RE: Radio controls on steering wheel problem.
Guess nobody has any ideas...LOL
Old Mar 10, 2007 | 11:48 PM
HemiLonestar's Avatar
HemiLonestar
I'd say look in the fuse box. I had my key on accessory the other day, and the radio display would fade in and out, but the cd still played. When the display showed, the controls worked. When it faded out, only the controls on the head unit itself would work. Whenever I fiddled with the key, it would flash. So I guess it could be any number of things.
Old Feb 16, 2009 | 04:39 PM
traderjk's Avatar
traderjk
Default Found the problem
I fixed the problem I was having with the remote steering wheel controls for the radio.
I found the problem while trying to fix a different problem. I got in my truck, turned the key as I had thousands of times before, but this time nothing at all happened. So I took the cover off from under the steering wheel where all the wiring comes into a junction box.
I found that my ignition wire had broken off at the terminal inside the junction.
I also noticed another small black wire that had been broken. I put a new terminal on the end of the ignition wire and re-inserted it into the junction box and I repaired the small black wire as well. The engine fired right up and I now have my remote steering wheel controls for my radio back. Apparently the tilting and un tilting of the steering wheel over time breaks the wires. Of course they cut the ignition wire to length with no play, so it is constantly being tugged on.
Hope this helps someone who may have a similar problem.
Old Feb 17, 2009 | 09:28 AM
Silver_Dodge's Avatar
Silver_Dodge
Moving to 2nd Gen section
Old Mar 13, 2012 | 08:20 PM
byrdman1981's Avatar
byrdman1981
fuse shared with wiper motor
