2001 1500 4x4 engine sputtering under load
Old Feb 26, 2007 | 12:10 AM
firetrainer's Avatar
firetrainer
Default 2001 1500 4x4 engine sputtering under load
While driving if I encounter a grade the engine begins to sputter. If I am towing it gets even worse. Usually not an issue on flat surfaces. I have found that if I kick out the overdrive and/or put my foot intoit that sometimes clears it up. Any ideas?
Old Feb 26, 2007 | 12:12 AM
Socha_62's Avatar
Socha_62
Default RE: 2001 1500 4x4 engine sputtering under load
Its probably not your engine, its the OD slipping/bucking. Mine does it in the winter only for some reason. Only in OD and when going up hills, ocasionally I've felt it on flat ground.
I dunped some Slick 50 trans treatment in there and it cleared it up.
Old Feb 26, 2007 | 12:15 AM
firetrainer
Thanks for the info. I noticed it last August and it's done it pretty faithfully ever since. I'll try the Slick50 treatment, can't hurt at this point. Thanks again.
Old Feb 26, 2007 | 12:19 AM
Socha_62's Avatar
Socha_62
No problem, hope it helps!
