New Truck
Old Feb 28, 2007 | 01:09 AM
ThainC's Avatar
ThainC
Default RE: New Truck
Worth attempting to do myself? And this I'm living in Canada, I'm going to assume it's going to be a bit more that $400, that's for sure. I'm thinking the FIRST thing I should do though, is jump on perhaps the reprogrammer. I'm thinking it maybe DF'd if people are saying they can smoke out there tires. I stomp the pedal, and I get a nice roar from the exhaust, but not exactly the greatest take off time that's for sure.
Chad.
Old Feb 28, 2007 | 01:15 AM
TMS Bill's Avatar
TMS Bill
Limited-slip ... open the hood and look up ... you should see a sticker right in the middle of the hood (at the front) that has a pretty good rundown on what you've got in there.
Old Feb 28, 2007 | 01:26 AM
ThainC's Avatar
ThainC
I'll be damned, didn't even see that sticker up there. Lesse, going from memory... It said the front axle was a Dana 44F (though, not entirely sure what that means), the rear axle had a ratio of 3.55, and it said something like Anti-Slip Differential. Not sure what else you'd want to know. I looked on the passenger side firewall, saw a black box with three bundles of wires clipped to it. There was a long white decal on it, but it was just a barcode and a ****load of numbers, I saw nothing else.
Chad.
Old Feb 28, 2007 | 01:30 AM
TMS Bill's Avatar
TMS Bill
The Dana 44 is the type of front axle you have. You also have a Chrysler Corporate 9.25" axle in the rear and your gearing is 3.55. Yes, you DO have limited slip ... that's one of the things that makes it hard to light the tires ... you're trying to light them both off instead of only one. The box on the firewall with the 3 wire bundles is the PCM (Powertrain Control Module ... your computer). The barcode and all that is probably just part numbers and what-not.
Old Feb 28, 2007 | 01:40 AM
ThainC's Avatar
ThainC
I still think something is up... But... who knows. I'll learn to live with it, and when I get some more disposable cash, I'll pick up the programmer.
Thanks All,
Chad.
Old Feb 28, 2007 | 02:16 AM
ThainC's Avatar
ThainC
Quick question though, if there is no DF and I grab this programmer, will I still be able to make improvements to my truck with it? And will it be relatively straight forward?
Thanks,
Chad.
Old Feb 28, 2007 | 02:36 AM
hometheaterman's Avatar
hometheaterman
I have the death flash according to the sticker and a LSD in the rear and mine will still easily light them up with a little brake and will sometimes without it.
ORIGINAL: ThainC
Chad.
hometheaterman
ORIGINAL: ThainC
Chad.
Old Feb 28, 2007 | 02:40 AM
hometheaterman
ORIGINAL: ThainC
Chad.
Sounds like you found the PCM. My white sticker has all that but then says something about the reflash. I'm not sure exactly what as I can't remember but it's whatever people said it would say if you have the Death Flash.
Old Feb 28, 2007 | 08:40 PM
TMS Bill's Avatar
TMS Bill
Not all "Authorized Reprogramming" performed were Death Flashes. There are a number of TSB's that call for a flash of the PCM unrelated to pinging.
ORIGINAL: ThainC
Yes ... you can use a programmer with or without a DF. As a matter of fact ... you can "undo" a DF with a programmer as it supposedly only pulled 4 degrees of advance out of the timing. You'll set your own timing with the programmer. All you have to do is follow the instructions.
