Tune Up
Old Mar 1, 2007 | 04:06 PM
tdmopar59's Avatar
tdmopar59
Default Tune Up
Well we are getting close to warm weather again which means i have a lot of maintance to catch up on.... Im thinking about using royal purple when i do my oil change I've read that its good stuff.... Now for the questions.... any reccomendations for plugs wires cap and rotor..... i am replacing my circle filter with a k and n circle filter do you know the size on a mopar performance circle filter i want to say 12.75x2.75 not positive..... Also changing the fluid in my dif... good idea bad idea? any other suggestions for routine maintance?
Old Mar 1, 2007 | 04:21 PM
tdmopar59's Avatar
tdmopar59
Default RE: Tune Up
btw i also plan on flushing the rad and putting a 180 deg thermostat in
Old Mar 1, 2007 | 05:58 PM
zique's Avatar
zique
Default RE: Tune Up
ORIGINAL: tdmopar59
Good idea!
To answer the questions:
1) Look for a good quality wire and you can go up to 8mm w/o having to upgrade your entire ignition system. Get a cap and rotor set-up w/ brass terminals
2) Read Silver_Dodge's post entitled "K&N FIPK no more" somewhere in there he listed what size (maybe even p/n as well) of K&N fits in the Mopar set-up.
3)Changing the diff fluid is a good idea, especially if it's never been done. It's super easy and often overlooked.
Old Mar 2, 2007 | 02:07 AM
tdmopar59's Avatar
tdmopar59
Default RE: Tune Up
thank ya does royal purple make dif fluid?
Old Mar 2, 2007 | 02:40 AM
dhvaughan's Avatar
dhvaughan
Default RE: Tune Up
http://www.royalpurple.com/prodsa/mgeara.html
Old Mar 2, 2007 | 03:18 AM
Cereal Killer's Avatar
Cereal Killer
Default RE: Tune Up
It depends on how often you change your oil. If you change it every 20,000 miles use royal purple. If you change it every 3000, use regular oil. otherwise you're just wasting money
Old Mar 2, 2007 | 05:17 AM
whiteram00's Avatar
whiteram00
Default RE: Tune Up
i used quacker state synthetic torque, i liked it pretty good,made my oil pressure go up an the engine is smoother now an is not all that high at walmart
Old Mar 2, 2007 | 07:51 AM
JarheadX's Avatar
JarheadX
Default RE: Tune Up
I use quaker state truck 4x4 torque oil or w/e too lol, i love it
Old Mar 5, 2007 | 02:25 AM
tdmopar59's Avatar
tdmopar59
Default RE: Tune Up
wat brands cap, rotor, wires, plugs and stuff like that should i get?
Old Mar 5, 2007 | 04:42 PM
suprchgrs's Avatar
suprchgrs
Default RE: Tune Up
I have a 5.9 but I used MSD SuperConductor wires 8.5mm with inexpensive NGK V-Power plugs and a brass cap/rotor all with excellent results in gas mileage and pep with NO ping / spark knock.
The plugs only cost me 10.00 & change for a set of 8 and the wires are a little pricey 79.00-90.00 but I found them on Amazon w/ free shipping for 66.50. I have the part #s but I dont know if they will fit a 5.2 prolly not. And the cap & rotor were 11.00.
