Biggest tire????
Old Mar 3, 2007 | 08:12 PM
dannthemann's Avatar
dannthemann
Default Biggest tire????
What is the biggest tire i can fit on my,no lift, 1999 ram 4x4 with 2 inch spacer's on each side? Some one said 33's with stock may rub but with it2" wider on each side ,can i fit 34s,35s?
Old Mar 3, 2007 | 11:24 PM
Ram4x4sport99's Avatar
Ram4x4sport99
Default RE: Biggest tire????
my understanding was that, after you add the 2" you can fit 33's, im kinda new to the truck scene, so im not exactly sure.
Old Mar 3, 2007 | 11:26 PM
Sinister's Avatar
Sinister
what would 33's be in canadian standards? 285s?
285s can go on your with no spacers possible rubbin'
with 2" spacer probably 305s.
btw, can you add spacers to any rim or what, Im wanting to put mine out 1-2" with my new rims to be ordered for spring.
Old Mar 3, 2007 | 11:32 PM
redandblackindian's Avatar
redandblackindian
I thought 285's were sized as a 31.5" tire
I have a no lift 2000 Dodge Ram 1500 and BFGoodrich all-terrain 285's and they fit just fine...
I dont think you could go any bigger though..
Old Mar 3, 2007 | 11:46 PM
Dodge4x4810's Avatar
Dodge4x4810
I have 305/70/16 (33") and they fit fine, only rubbing at full lock on the control arms.
Old Mar 4, 2007 | 01:36 AM
dannthemann
so could you fit any thing bigger than 33's?
Old Mar 4, 2007 | 02:22 AM
Sinister's Avatar
Sinister
with a lift yes. without, maybe only 33s
Old Mar 4, 2007 | 04:07 AM
hometheaterman's Avatar
hometheaterman
ORIGINAL: redandblackindian
285's are like a 32.8" tire. I think thats what it is anyway.
Old Mar 4, 2007 | 04:16 AM
zique's Avatar
zique
The number 285 you see is the width. The height is determined by a ratio computed with the next two numbers. For example:
Tire one: 285/70/16 is a 32 x 11.22 on a 16 inch rim
Tire two: 285/75/16 is a 33 x 11.22 on a 16 inch rim
To answer your question. I have 33x12.5 right now on my stock suspension w/o any rubbing whatsoever. But it depends on the aggressiveness of the sidewall and the actual measurements of the tire. Different manufacturers sizes come out a little differently according to the weight of the truck.
Old Mar 4, 2007 | 06:15 AM
Silver_Dodge's Avatar
Silver_Dodge
The lift is not the only factor that determines if you will rub or not. In fact, it is not as important as the backspacing/offset of your rim.
