need a picture
Old Mar 5, 2007 | 10:16 PM
jrleslie's Avatar
jrleslie
Default need a picture
does anyone have a pic of the rear exhaust hangers on a dual exit system. I can't figure out where these stinkin' things are supposed to go. they are about 8 inches long with a curved end and a metal strap on the other. Got it on Ebay, no directions.
Here is the kit. the hangers can be seen behind the tips. I really appreciate the help.
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
Old Mar 5, 2007 | 11:25 PM
jrleslie's Avatar
jrleslie
Default RE: need a picture
Here is the hanger. Does anybody know?
[IMG]local://upfiles/33644/8B423398EC2A42DB95B41FB0F8BFF14C.jpg[/IMG]
Old Mar 5, 2007 | 11:40 PM
padodgeram's Avatar
padodgeram
The ends with the holes mount to the frame (anywhere u can find a hole) the curve end is where the pipe is against it and a exhaust clamp is used ..which ever hole u use to keep the pipes level and yes u mite have to twist it a little the the curve end is even with the pipe and u can tighten the clamp on it... its dark outside cant help ya with pics....
Old Mar 6, 2007 | 02:16 AM
sbrunn9's Avatar
sbrunn9
I have the same exhaust and if I get the time and can figure it out I'll post a picture tomorrow. I bent the brackets into an L and drilled holes right into the frame rails on either side then just bolted em in. I'm pretty sure they're hangin about 1-2' ahead of where the exhaust exits and like I said if I can figured out a picture sometime tomorrow I'll post it.
